AlbertoP
Hi, I'm brand new and it's my first post.
I wanted to ask you for help to understand better how I can make a decision given my total ignorance about the cams. I know that these questions on the forums make a lot of them and the most experienced if they can slave them. I also ask you only a tip or an article to read to guide me.
I do work on behalf of third parties of milling and turning cnc, small series, 2-5 pieces at a time mostly. non-prototyping, simple things on average like pine trees, aluminum blocks, rollers, forks, etc. work all materials from plastic to inox to aluminum hardened up to special alloys.
as I need to speed up the times I thought that a cam could help me to reduce a bit the programming time (now we program on board machine on fanuc controls in iso for milling, while in mazatrol for turning) I have 2 milling centers (both 3 axes with nikken divider) and 2 cnc mazak lathes (one with motorized but not c or y axis).
I don't know I hope I've described what you needed. .
Now I have made me make a lot of quotes, cat 5, solid-edge cam, open mind hypermill and mastercam, to today those that seem more to my case are open mind and mastercam, but I don't know, can you give me some opinion?
quote open mind 23000€
estimate mastercam 12500€
signal the message
signal the message
