choose the ball order and its table parts
  • Thread starter Thread starter cerveza
cerveza
Good morning.
here is my situation:
I have to make a table of an explosive with its distinct parts.
if I create one with the automatic ball, it gives me a random "graphically" order: in the section sorting options I can only choose according to the location of the file, name, author, etc. with result that graphically the pallinatures me find them "disordered", for example the 1 in the top right, the 2 in the bottom right..
I was wondering if there is a possibility to create a ball first with order graph to my pleasure (who knows, maybe clockwise), but still with increasing number (1,2,3 etc) and then connect the table maintaining the order di numerazione chosen by me.
I hope I could explain. .
Once the ball command is activated, you need to activate the numbering and link to the list, then start manually touching the pieces in the order you need.
alternative once you automatically select each ball and give it the number: in case of conflict with another ball asks you to confirm whether to change the number or not, but also to update the list parts
see also in the options of car ball, you can choose both the shape on which to react the balls and order.
Okay, almost solved. .
now the problem is that it only identifies me ashes, and not individual components
[MENTION=240]be_on_edge[/MENTION]I read your answer now.
in the "list check" tab select the option "atomic list (all parts)".
