Plaguebreath
Good morning to all, I have the following problem and I ask you if you can solve it somehow or as you do to bypass the problem.
I have a compound x set. At this point I ask for a separate component of this mold when creating an excell file made as follows.. .
No. q.ta standard size rough material hardness
67 2 cooling blades l135 14.7 x 2.5 x 135 stainless steel
Now, my scheduling program does not support an import of the toptron distinta and I have to manually create a commission composed of all the distinct voices with the rule type:
numbercommitted/numberdifferent
all right though laborious, but here's the problem, after a while it happens that maybe in the project they have to add y normalized to the assieme. with the new exit in distinct but the numbering changes!!!! and therefore all the work done before is to be thrown!
Now I wonder, is there any way to block the numbering of the various components of the assembly for fre so that the next pieces added start from the last number in db + 1 ??? or what techniques do you use? thanks for patience, good day!
