b243970
Hello everyone, I found myself with the problem of having to simulate the movement of
a chain that fills on two toothed wheels, as I found many posts
with so many perhaps but no definitive solution, place what I found
I for the benefit of all:
My chain is made of sub-assisted by a dozen of meshes mounted
together.in physical simulation, no function bond
belt/chain(I used it to get the route and then erased because'
if you impose that the roller follows the solidworks path you "forget" the
contact with teeth), ultimately I have a rotary motor on the first wheel
e...126 contacts 3d(work with a 10 year old computer and simulated
15 seconds in a half hour, I thought worse), exactly as in reality
the second wheel does not turn thanks to the function but thanks
to...catena
. ..unfortunately there is no way to set a durable motor
to the wheel conducted and therefore the chain "ball" also on the top and
He shouldn't.
I would like to post a video altogether but it tells me "unsuccessful sending", the file is in rar and falls into the maximum size...boh.
to...catena
He shouldn't.
