enrico1979
Hey, everybody.
as I have already said in an old discussion I come from pro and I decided to take the big step.
in pro and it is possible to apply external loads and determine the trend of the binding reactions of joints according to time (or any other variable extrapolation the graphs, which also makes inventor).
to understand us for a hinge connection it is possible to determine the radial binding reaction, or for a suspension the compression force and traction agent on the spring (which can be seen through arrows that vary in size, proportionally to the magnitude of the force, direction and direction during the animation of the mechanism).
being cai probably the top range cad I thought that such a possibility was contemplated, but dispelling the web I found myriad of kinemstism annalisys tutorials where it is possible to determine the degrees of freedom and any interference.
Am I wrong?? is it possible to determine the binding reactions of joints (and not in fem environment) as in pro and (which will know who knows the analysis that performs to this task are the dynamic annalisys executable in pro mechanism) ?
