Cinematography.
  • Thread starter Thread starter Fabio74
Fabio74
hello guys help me please
I ask politely if someone can help me, I have a problem with cinematism is the first time I face this problem I try to be as clear as possible I will also attach photos. I have a fulcrum with a plug, moving my lever I have to move my cart linearly , I fixed the lever with a pin to the axis of my plug , but I do not know how to fix the cart to the lever so that once I put in motion everything I can not do the right movement, then lever rotates around the fulcro , cart moves on the x axis. thanks guys. good workCINEMATISMO.webp
there are two methods to get what you want:
1 - using cam command
2 - with cinematic connections, and in particular, insert a point in correspondence of the center of the hole of the lever, then create a point bond on surface and select the point and a plan that passes through the asola of the cart and transform it into a general connection. at this point add two flat connections by selecting the horizontal plane of the assembly and that of the cart and the vertical planes.
I hope I've been clear, it's easier to do than say.
p.s. probably missed that in our forum, at the beginning, a presentation is required in the special space. try to fix it.
thank you so much for the help now I will try to put into practice your indications. but I seemed to have introduced myself, I must have made some mess then, I thank you and I will let you know if I managed to move everything. good work and thank you 1000
presentazione.webpI presented myself in this section is right or I had to introduce myself to some other section, sorry if I break you.
Thank you, I think I've presented myself right now....in the afternoon I will try your instructions.thanks and good lunch to all.
fabio
Good morning dani,
I have tried to follow your instructions but I have not managed to move anything, with the command cam, for me unknown, making the selection of the first cam, so I go to select the surface of the hole of my lever (no fulcro) , then I select the second command cam and I go to give it the surfaces of the compass of the cart, I click on ok and I get out "the two cams can not be on the same body
It would be enough for me to do a third of what you can do I've seen your interventions...... you're on another planet...
Be quiet, with 7 years of experience with pro-e, you will also know how to tame cinematisms without problems.
However, don't offend you, but since you're fairly fast in this environment I suggest you take a step back and start with more septical things.
I attach an image of online help, there is a very well done example with which many of us have left, if you follow it carefully will clarify many things. then if you still need we will return to your mechanism.
greetings and good weekend.
