circiito idroumico
  • Thread starter Thread starter RobertoIanniello
RobertoIanniello
Hello, I am a mechanical engineering student I have to design a didactic test bench of a closed hydraulic circuit with a centrifugal pump. I would need teaching material and at the same time if it is possible, a scheme already made in such a way as to have an idea.
Are you talking about oleodynamics? Centrifugal pump sounds strange to me with oleodynamics...unless it is moved by a hydraulic motor.
test bench to characterize what?
I have to make a circuit with two pressure tanks and a centrifugal pump, going to study and then design the length and size of the pipelines
that means nothing.
like fluid?
characteristics to keep under control?
Do you have to choose the pump? or is it assigned and you have to adjust the rest of the circuit?
Where are the tanks? one upstream and one downstream? underwent or overwhelming pump?
Your question is too vague. It's like saying: "I have to make a vehicle with wheels and a motor".
Go figure out if you need a motorcycle or a truck.
