circular series that advances in one direction.
  • Thread starter Thread starter costruzione3d
costruzione3d
Hello, everyone!
I find myself having to make a 'asola on a tube diameter 2". So far no problem. the fact and that this asola I have to do with rotation and advancement.
that I have to do 6 out of 360 degrees but these must not remain at the same height z
well, they must climb or descend along the z axis with increment from me established (type as in the linear series)
aid
on the series of 6 out of 360 normal to the tube you can still reason but changing the z you have a number of different objects, so no more a series
would be a series with the path of a propeller.. I read around ke this was a method used on holes.. but I don't come out with a shape-shaped "s" or better I have to create one by one.. and I wanted to avoid
perfect thank you 1000! I almost got there... I missed setting up "length of the curve".
super thank you all!
