circular text
  • Thread starter Thread starter pierluigip
pierluigip
Good morning to all
I should make a silkscreen with circular text as from attached file
I can't give reports to the text to get more written as reference the same circumference and especially to place them as I want, is it possible to do so?
use sw 2011 sp 4.0
thanks to all good work
Good morning to all
use sw 2011 sp 4.0
do two lines that start from the center and arrive at the circumference, example one before the sixteenth and one after, so divide the circumference into arches where you need to have written, whip the writing to the center of the arc that you create (you hold these arches in lines of construction and eventually you do the circumference that you wanted in normal line if you need without restraints.
the attached file to be clearer
but you can also trace a circumference, and then in instruments > instruments of the sketch > divide entities and divide the circumference with this command, or you already draw arches, in short, look a little what you are more comfortable :biggrin::finger:
Thank you very much, your suggestions have been really helpful, working with the texts is a little bit brigorous, but eventually you can
