gio.max
ban on cheeks,
I need to create a thing like an image that I attach, in support of a glazed dome (made at the moment with curtain walls applied to a semi-spherical form generated with the masses, if you have better ideas, type glazed roof come forward), it is possible to make it agile with the tools of revit, or it is better to import it from the outside from a sketchup file? At the moment the size of the object I found is not correct, so I would like to understand what is best to do so as to lose as little time as possible, trying to maintain a minimum of veracity in the measurements.. .
