Iraz
I write here because I have a dilemma about a question of pressures/ports and I am a little rusty on the topic (or rather, I was accustomed to seeing "unique" conduct without particular shrinkages or other and now I have a different situation).
I am drawing a system to cool components; usually in the company we pass copper pipes with water inside; There are not so many calculations, indeed, this has been empirical for years.
Today I want to put some problems on the plate I'm asking myself several questions and here falls the stage.
We usually use diam tubes 8 or 10 depending on the encumbrance mainly. today's machine is more complex with ducts that branch upstream and gather downstream.
you want to start with a 3/8" tube, I don't know that prevalence has the pump but it is estimated that it has about 7 pressure bars (?).
the path at a certain point is issued a 3 pipes of diam. 8mm and then gather in a single passage with 8mm tube too.
Afterwards from that only 8-tube goes back to 3 by 8 and then you can 3/8".
what I ask myself is: what is the diameter that "command"?
because if I have a pump it means that I have a constant external load, but the sections change and therefore change pressure and speed of the fluid.
But I can't think that the fluid just burns to the rub, I'll have limits. and here I am doing a thousand paranoias not being efferted in plant matter (although I have also worked in the middle of "hydraulics").
all this because at some point I don't know if I agree (for parts/space issues) switch from 3/8 to a 1/4 shrinkage and then enter the 3 8mm tubes and then into the unique 8 (and then symmetrical return route).
I imagine that many will smile, but unfortunately not handling such calculations for a long time I don't feel confident in evaluating water behaviour to the various strokings.
Hello everyone
Hello everyone
