ansyolitico
I wanted to ask you, to mount the gmz(30) nsk series nah with screw from below you have to use a m8? because from catalog I see thread m10 but also ødrill from 8.6 mm, I searched and there are no codes to identify a skate with only passing hole, so I guessed right?
but if you use m8 in theory should not keep less? or are the declared forces calculated with the m8?
allego screenshot manual
