mauri53
greetings to all
I have a problem with the parametric: I elaborated an architectural design of a 1 /100 scale construction with a unit = a millimeter. as my ultimate intention is to realize the model in plywood with its recesses, I used both the geometric parametric p.g and dimensional p.d. the thing works perfectly as with the p.d I can select the thickness of the plywood with which I want to make the model. But my goal was also to be able to scale my design in order to achieve different scale combinations. this unfortunately I failed to realize as the dimensions relative to the p.d. are not scaled (with the command scale). I would like to know if there is some variable that allows me to update the parametric quotas according to the scale used, or if there is some other furbata that I can use in that sense. (I am forced to use a parametric quota to establish a firm point compared to a hole.
maurials
maurials
