hello guys I have to work on the bases of a motor, I have cast iron casting with an overmetal about 5mm, could someone give me advice how to start milling? I never had experiences with merging crude... thank you in advance
very generic question.
What work do you have to do? as you are equipped in machine, programming, etc.
I can tell you that the cast iron is working well does not have particular criticism.
much on two feet on the bases motor you will have to do the sanding starting with fresa to inserts, then milling of some shouldering with integral cutters in hm, holes and threads.
How many pieces are they? if you're fasting and the interesting amount I suggest you turn to a "serious" distributor and advise you
