co-ordinated input problem
  • Thread starter Thread starter edward
edward
Bye. .
I got a problem with autocad working in 2d: until this morning if I had to create lines in a drawing I specified the starting point, I entered the value of the length needed and I specified a point also distant to the snappato line to make it lie where I needed it. from today the prog prioritizes the final snap and extends the line to the aforementioned snap by ignoring the input length. in options > user preferences > coordinate input priority is selected "keyboard input". cmq I tried all 3 options and the result does not change. .
I'm obviously not a big autocad connoisseur.
Any help?
Thank you!
osnapcoord
type: whole
saved in: register
initial value: 2
determines whether the coordinates inserted in the command line replace the current object snaps.
0
the object snap settings have priority on the coordinates inserted by keyboard.
1
the keyboard input has priority on the settings of the object snap modes.
2keyboard input has priority over the object snap mode settings, except for scripts.
osnapcoord
type: whole
saved in: register
initial value: 2
0
1
Thank you for the speed of the answer. the right option should be 1, but unfortunately the problem does not solve.. .
the good thing is that when I write the length and tab to specify the end of the line near the value it shows me the padlock and it appears editable the inclination, and if I click in the void it is fine, but if I use the snaps it ignores the input value. :36_1_28:
