code iso for lathe fanuc 2 axes
  • Thread starter Thread starter COMTREX
COMTREX
Good evening.
I have a turning problem, I look for a string of code for the fanuc lathe of 2 axes.
So the working and the lateral throat, where the throat is wider than the width of the tool, at the end of the processing the tool is always close to the flank or right or left, to prevent the tool from crawling on the sides and creates the rifling, how can I avoid it? .
I look for a code iso to detach the tool and get out quickly without touching the flank.
I write an example of finishing program of a facade of the throat.
10 m2
n 20 g97 s700 m4
40 m2
n 50 g0 x103 z-31.75
n 60 g79 x24,5 z-31.75 f0.1
# 70 g x170 z-31.8
80 m
90 m2
100 m
n60 is the finish of the facade, n70 and the quick return, what code do I have to insert to avoid the rifling on the facade? ? ? .
I hope in a vs. friendly response greetings.
comtrex
Good evening.
10 m2
n 20 g97 s700 m4
40 m2
# 70 g x170 z-31.8
80 m
90 m2
100 m
comtrex
stop the spindle and then send out the tool quickly... :smile:
p-h
p.s.: I am in vacation for which I might have said a very great:
Hello, in the code you put when you send back the tool quickly moves diagonally... .
10 m2
n 20 g97 s700 m4
40 m2
n 60 g79 x24.5 z-31.75 f0.1
n 70 g0 x24.5 z-31.8 (I added this point)
# 80 g x170 z-31.8
90 m
100 m2
No 110 m
...in this way the tool does not crawl on the surface just worked because before drawing in x with rapid movement to n80, it has gone away in z to n 70. Let us know, bye!
