maxopus
a question (every one comes to me).
with a friend we designed a machine based on a hot vaporization system (of simple water).
The machine works however, being my brain always looking for better solutions, today I came up with something that, if possible, could simplify the system.
I thought about the technology used by pump injectors.
As it is not necessary that the steam is hot (but it is necessary that the water particles are very small) then it could be much simpler, energeticly less expensive and much less bulky to obtain vaporization for high pressure instead of for high temperature.
It would be a much simpler thing than a pump injector in the strict sense, as it should have much less expensive and limited workloads over time simply controlled by a timer.
I also heard about ultrasound vaporizers.
in practice it would be very finely vaporizing 250 cc of water per minute.
Is there any one of you who has experiences or useful news in this sense?
Thank you in advance.
