color axes cartesian origin
  • Thread starter Thread starter Lorenz578
Lorenz578
Good morning.
when you start a sketch, two lines of black color are represented, one horizontal and a vertical, which intersect then in the origin.
These two lines are black (the most marked vertical, the lightest horizontal) and when designing a line of sketches passing through the origin (horizontal or vertical), this overlaps with the lines of origin and is no longer visible (as once defined becomes black).
is it possible to change color to the lines of origin, or rather not to see them, leaving only the origin visible?
Unfortunately I always come to make comparison with sw, in which once selected the plan on which to draw the sketch, only the origin is visible and nothing else.
never done, but it probably is your color scheme (I use the "base" and I have distinct colors)1620291219046.webp> color > customization schemes
It can also be that in your basic template there are already projected axles and that therefore you find them at every new part, in such case you should remove them or set them as a construction line, more distinguishable.
never done, but it probably is your color scheme (I use the "base" and I have distinct colors)View attachment 62022> color > customization schemes
Yes, effectively changing color to the background, the lines stand out better.
I have selected the background "clear" because it is the one I work with better and I get tired less the view.
I try to get into the template and see what I can combine...if I can:)
in the options, under the tab "scratch", at the right at the top you can decide whether to view the lines of origin axis in sketch mode. then the point of origin is projected to create a new sketch.
Hello, zac.
high right where exactly? I can't find the options you say.origini schizzo.webp
