color map
  • Thread starter Thread starter Polymar
Polymar
It seems that no one has had this trivial problem ... at the start of each td session I would like the color map, under the format menu, to be set on something different from the default one, for example bluedark. is it possible to do it and how? also saving and reloading the configuration, this setting restores on a annoying white background :(
Thank you in advance!
I found the solution, however much easier than I thought, in fact just save in the .e3 template the new color map. After opening each new project, graphic settings will obviously be maintained. Bye! :
