color sketches on flat model
MARCOC
Hello everyone
on a part of sheet metal that I also move the file (a part of test to make us understand) I do a sketch ceh then I have to display on the table, and on the table I have to change the color, now comes the beautiful, the change color makes me do it only on the piagata configuration, if I activate the flat repetition, the color is set to that of defaul and there is no way to make it change
to see it colored you have to convert into entity on the table and put on a right color level the converted circle.
click and press the "convert entity" button. Basically you must have a sketch in the view to color it, you cannot color a sketch of the model.
Okkk. I try, but it's not true that you can't color the sketches of the model, look at my image, what you see red and the same sketch that you see gray left, solid in the flat repetition brings it gray even if it was originally red
sketches in the model, sometimes, I color them too. But when you go to the table you see them gray and you cannot color sketches of the model in the table. You can color the sketches created inside the table, so I advised you to make a convert entity. In this way you have sketch objects created in the table that can be colored.
now comes the beautiful, the color change makes me do it only on the piagata configuration
I agree with what is said by @re_solidworks , but I would understand: Are you saying that in the design environment you can color a sketch displayed by the environment part? if yes, explains the procedure, it could be useful to other users.
you cram, what you see red and a sketch on the part, displayed at the table, just select it and then go on the color command1619770531632.webp
and for what I don't understand what reasoning does when you activate flat repetition
I take advantage of a clarification. I didn't work because I tried to color a sketch text. I had created these texts to have a unique numbering of a series of ribs and I showed the text in the laser table so that I could laser the text. if you try to color a text entity does not work, instead with other sketch entities no problem.
with what version of solid mass? ? ?
It's on my profile, 2019. However, I doubt that this particularity is involved in the version change.
re_solidworks also has 2016 and possibly can confirm or not this fact.
