colore hair and fur
  • Thread starter Thread starter lattu
lattu
with the 2018 version of 3d studio, in addition to the problem of the arnold rendering engine, I met different problems, some deriving from incompatibility driver of video cards not to throw, but almost all solved except one or the color of the hair and fur modifier that "takes the color of the object to which it is applied. Does anyone else happen the same thing?
I realized that it doesn't depend on the rendering engine and even on the PC components because it happens to me on another personal.
Is there any way I can escape?
I have never applied that modifier and I have no arnold to verify, however, at least judging by the following tutorial, it seems that arnod does not take into account the colors set by default in the hair and fur modifier, when applied to the object, and that therefore you have to work on the colors when you create the materials.
I don't think it depends on some hardware incompatibility.
try to insert some aec tree to see if arnold does the same with the colors to assign to the polygons to which to apply the textures of the foliage. Usually 3ds max assigns green color to those polygons. just to see if arnold does the same thing or behaves like with the hair and fur modifier
as a motor I reinstalled mental ray directly from the site envy.
I think I understand where I'm wrong, now I can't, but in the afternoon I'm sure I'm going to have some proof.
Okay, I took a while because it wasn't what I thought... just set themr prime instead of the buffer in the render settings
