coloring parts in .idw
  • Thread starter Thread starter Isa75
Isa75
Hello I am aberto, new user of this forum.
I would need help, I find myself having to deliver to customers always files in dwg. for greater clarity a customer asks me if you can represent the individual parts with different colors. is it possible during the transformation from idw to dwg of autocad already make them color each part in different color? If not, do you suggest a possible solution?
Thank you, hello!
if the part is already colored in the idw, it is exported to dwg such and which.
I did not understand if isa 75 talks about exporting a .ipt part or a .idw board.
In the first case your post doesn't make a wrinkle.
In the second case I see it hard: I tried to put in the table idw the part with the shaded view, that is with its colors as you see it in the environment part, but in dwg I can export only the edges and the tangent lines, not the appearance of the surfaces, that if I do not err, in autocad you can see only using samples, so no colors.
maybe you need to set some parameters?
clearly speaks of export idw->dwg, does not say shadowed views. in the browser in idw go into the portion in question from dx mouse, property, and select the color. the lines will color and will be exported to dwg autocad.
ok, the various faces will obviously remain without any color....but here I add, if we want to export the shaded view of the table .idw in dwg and maintain coloring, there is a method to do it?
I know that from the properties in the browser I can give a different color to each part and that in autocad the colors will remain the same however in each view of the idw I have to change the color of that part. in a great assembly it becomes really hardworking.
