coloring surfaces with delimitation
  • Thread starter Thread starter giocamb
giocamb
Good day to all
I write you in the catia forum because I do not use it and I wanted to ask you a question, I work with ptc creo and I received a math in catia step I have a surface that does not shade is a unique skin, shaded has 2 different colors delimited, I with creo I have a similar command but creates a copy of the solid surface and then it is bounded through a sketch.
I wanted to know what kind of command he's got to see if it's a feasible thing with my cad.
good day and good weekend
I don't think there are many systems or commands (but I can be wrong). . .
in your case I imagine the result of the step is a unique skin as it is generated by the union of multiple surfaces that have been colored previously, to verify it you have to try to separate the various surfaces that compose it (in the command chain separates)
to obtain a unique surface with different colors, with casket:
create individual surfaces
with the command joins you make it a single surface
using the appropriate display (shading with edges, rather than simple or smooth edges, material etc.) selections the affected surfaces and colors.
Running the step, you lose the historian and remains only a unique surface but with different colors.
then wanting there are modules that apply a sort of "adhesive" that however (I think) does not pass the step.
Let me know.
years ago
Thanks already ok I understand how it works on catia, instead with creo it works with another function but not from the same caty effect, it creates a delimited area while keeping the original below, but I can assign a color without overlapping to the other.
