colour survey used
TECNOMODEL
I would have a curiosity, what color settings used in work?
I find a certain difficulty with the colors of the sketches, especially on geometry projected by tireless edges to see the lines.
I activated in application options in the color tab the light gray pattern with background to a color.
what do you use to facilitate viewing?
thanks and good work
Hello, I am not satisfied with the colors that imposes inv...
in the end I use the typology "presentation" with nuance that in the end seems to me the best. . .
then to print images with white background I downloaded the application "screenshot" so I don't always have to change background for various prints and images.. .
ideal would be black background, like autocad style, but it does not have good sketch colors.. .
Thank you. I'll try it.
At first glance it seems not bad, I will see working.
There's no way to change the sketch colors, is there?
to me it seems a big limit, especially on a cad of the kind that has a wide spread and has a cost that places it in professional products of medium/high range.
in the template you can change by default.
when it is bound....you are right, it does not change the color.
si chiama "coolorange screengrab" si trova in autodesk exchange app.
c:\programdata\autodesk\applicationplugins\coolorange_coolorangescreengrab.bundle\contents\documentation\coolorangescreengrab.htm
