comando nx "currently hidden"
  • Thread starter Thread starter solidfede
solidfede
Good morning.
I should add a view of an explosion in a draft but the command "add view" is unusable, tells me "currently hidden" and I can't unlock it.1568273003633.webp
you do not use that command, but the basic view command.
Sorry the question: but did they put you on nx without a minimum of training?
In fact, I was working in a rectification plant and asked me to start designing and learned by myself...when I need to ask around...but this is another story...pietosa....
However, I don't have the view on the list of the explosive and I don't even see it with the Orient tool.1568277748003.webp1568277789601.webp
Thank you so much now I can fit it correctly.
by honor of the record in other codes I can put the view exploded without selecting the file from that window... and those other files I made them....misteri.
I owe you a drink _ Thank you.
depends on the default. Do you work in master model? I mean, do you draft it in a separate file? because that is what determines then the default that changed from release 9, but it is a long speech.
Look, I'm veined. :-)
Yes I work in master model, but also the other files where I can do it without looking for the code are.
beyond the explosive I created it in the draft file model, and not in the main model, but it's like I always did.
I'm Romagna! prefer Albanian or Sangiovese :roflmao:
