combine error "two to geometric condition"
  • Thread starter Thread starter Prothean
Prothean
Hello everyone, I can't use the "combine" command to join two complex geometry bodies within the same part. the error that gives me is "two to geometric condition". I'm going to see the interface between the two bodies but I can't figure out where the error could have created me. Does anyone know how I could solve this problem? use solidworks 2019
thanks in advance
without files, without images is practically impossible. you should imagine something complex that is not even described.
attach the file
I can't tie in any way, the file is too big! are 25mb of sldprt that does not reduce much even zipping
don't join them because there are a lot of areas that intersect or have no perfectly combing faces.
for those who want to try the union of the two bodies here is the allegianced file.
the weight was reduced by transforming the part with bodies externally referred to in part with bodies without references, moreover I added the function eliminates bodies that allows to further reduce weight
