combined share
  • Thread starter Thread starter giacio85
giacio85
Hello everyone,
I searched in the forum if by chance my problem was already discussed but I found nothing about it.
I am listing a plate with many holes and to save the space of the sheet I decided to use the cumulated quotas (for those who had never used them are those quotas where it is indicated with a circle zero and then with an arrow the quota to which the object to be listed is placed).
when I find two nearby objects (for example a hole at 7.5 and another at 10 mm from zero) the two texts overlap, with v5r18 I select them all, I clicked with the right and I select "alline in the system" and they aligned all automatically by moving the quota texts so as not to have them overlapped.
with sight I had to install caia v5r19, I did the same same operation and it does absolutely nothing, maybe I have to set some options I don't know? ? ?
Thank you in advance who will give me an indication.
