make the solid cylinder full. use the combo command by subtracting the cylinder from the parallelepiped and ticking the voice "maintain tool body". you will find the solid of the perforated parallelepiped of the outer dimensions of the cylinder. go to the browser where there are solids and turn on the cylinder body that will appear to you again. now use the emptying or hole to create processing only on the cylinder.I'm doing some evidence with the command, but I can't get what I want.
In practice I would like to combine a pipe with a solid so that the hole of the pipe remains.
I tried all the variants but the central part of the solid always remains full.View attachment 40507Is there a way to do that?
ops, better hole than you do it on the cylinder. emptying the whole partmake the solid cylinder full. use the combo command by subtracting the cylinder from the parallelepiped and ticking the voice "maintain tool body". you will find the solid of the perforated parallelepiped of the outer dimensions of the cylinder. go to the browser where there are solids and turn on the cylinder body that will appear to you again. now use the emptying or hole to create processing only on the cylinder.
