command centering components
  • Thread starter Thread starter ciobinn
ciobinn
Good morning.
I wanted to know if there was a command on inventor that I find on solidworks
Specifically when positioning two parts on a set, putting the bonds (double) in solidworks I have between the advanced functions "center profile" or I can select two faces so that it autofocus, while in inventor I have to digitate the measure in the offset, with obvious differences both in terms of "time" in detecting the various measures, both in terms of potential errors (I have to type the measure with probability of error), and in terms of future changes.
Thank you!
I think you should work differently.
I usually refer to the coordinate system, a profile drawing almost always in the center of the system itself.
so doing together by using the plans or origin of the coordinate system, if I change a profile I do not have to worry about going to recheck the position of the part together.
is the system I use now.... but actually trying the solidwork command I just described, the thing is much faster..... (cmq thanks to your advice)
