command crea contour
  • Thread starter Thread starter Naeto
Naeto
Hello I need to create polylines from polycons, when I go to run the command creates contour, it makes me mistake because it finds open contours
I would like to know if there is a quick way to find these open points... .
The fast way is to create the contour
However you can set the hpgaptol variable to a value greater than zero, so that as long as the non-closing falls within the hpgaptol value, autocad itself will close the contour.
excuse me if I interfere but the hpgaptol variable acts only on the tolerance of the contours for the creation of the restraints. not on the outline command
I checked, you're michina right.
a route (if you can't find where the shape is opened) could be to set hpgaptol by creating a detachment and after returning the contour with the appropriate option of the dash command
exact...or, zoom very far away the entities open until you perceive the gap more to video....in this case the outline command will work! ;-)
what version of autocad you use?
from 2010 the small points left open are ignored, and the contour is created correctly.
in 2011 when creating a retino (I did not check out) are highlighted the areas open with small red circles.
very useful function to repair safely
the highlight of the areas open with red circles, and this also happens in 2010.
green 2010
- in the creation of contours ( contours control) what influences the possibility of creating them is the zoom factor, so if at video I see the detachment the contour will not be created and the red circles will appear. but if I decrease the zoom to the point not to perceive such a gap, the contour is created;
- in the creation of restraints (tracing control) what influences the creation of contours is the hpgaptol var or the space tolerance option found in the dash setting window; therefore the non-contact points are ignored, by virtue of tolerance (defined in design unit) set
Bye!
ok going to set hpgaptol you can create the hash, but if I want to create a closed polyline to send to a cadcam the problem remains or is always open.... and I just need to send the figure for a cut to the pantograph..:confused:
bb
depends on what parts; However, in general, if you have an unclosed break, make a zzoom away until you perceive the discontinuity, and with the outline command create the polyline.
or, if you already have the restraint, even easier: you have a "recreate contours" button that allows you, from a hatch, to recreate the closed contour that generated it,
to me it doesn't work.......tested with the 2005 and 2008 version.
with the 2010 version is ok.
bb
