rpor66
starting from the discussion "lisp to insert progressive numbers with preview on the pointer" I realized the command that inserts the text with preview on the pointer, possibility to change content, height, inclination, width, storage of the inserted texts reusable subsequently, rotation and justification to the flight, staggering of the insert point on the variable vertical, automatic numbering.
the command is called distext, the 2 attached files copied within a directory included in the autocad paths.
during the execution of the command a command legend is shown:
tab:rotate 90° - l:left - r:right - c:center - m:middle - s:setup - i:isometric
s is the option that recalls the dialog box
with the option the texts align to the isometric axes via the f5 button.
bye
bye
