command for sheet - forming instrument
  • Thread starter Thread starter Furnu87
Furnu87
Hello everyone, I'm new to the forum.
I work with solid works and I need a hand because I don't remember a command.
I'm supposed to make some loopholes in a sheet cover: I remember that I must use "project library/forming tools/louvers", but when I drag it inside asks me if I want to create a derivative part: click yes (otherwise opens the louvers as a part) and place it (as I would with a part inserted with the command insert part). I don't know how to move on anymore. if I do the command "forming instrument" and select the plans tells me that it is not a command for multiple bodies.
What do I do? Can anyone help me?
What version do you use? I with 2010 do not have any problem also on multibody sheet function and it is all-regular.
Maybe I didn't understand the question? :confused:
use sw 2009 sp. 5.0
But I still did, but I don't remember. but once you translate, you automatically generate?
thanks miki1967!!! :finger:
with your suggestion I solved the problem! !
thanks to you geppetto for the help!
Have a good day!
