command line
  • Thread starter Thread starter genbel
genbel
Good morning
to someone happened to open autocad and find themselves with the command line of huge dimensions to the right
I tried to increase the screen resolution to try to resize it
but without result : impossible to reduce it
Is there any variable that controls the size of the command line?
What does it mean by huge dimensions? the text? The width?
and why on the right instead of on the bottom?
It stretched all right
if even the disanchorus known that the line comes out of the screen
this cause that when I do an f2 to see the sequence of commands , fills me all the monitor
Thank you very much for the indication only partially profitable
I found no indication for my case
opto per anchorage command line and to the f2 key I get a display window
external and not invasive
Thanks again
