command matrice
  • Thread starter Thread starter michina
michina
advice. .
using the matrix command (revit 2010) I realized that it acts in a "strange" way... I explain.I am able to place for example 5 chairs around a circular table
1st case: sometimes you move the chair positioned, matrix object
2nd case: if you immediately set the 360° angle value, the command is not executed and an error notice appears
Have you ever happened?
thanks in advance
no..."unfortunately" also happens using simple lines model/detail, with which I designed a chair...I believe it is a "problem" of the master command...I believe. .
... the 2010 version I uninstalled it and I can't verify ...
It also happens with the current ver 2011...and it happens to me if drawing of the lines of detail to which I associate a retino, I create a group, and I use the matrix. .
It doesn't happen to me.
object made with lines of detail and retino
but did the 360 type it from the options bar or the temporary quotas back? because it only makes me mess up in the first case.. .
in both cases.
the angle, in the options bar, must be inserted and confirmed, after setting the center and starting point of the angle matrix
