command promuovi
  • Thread starter Thread starter novizio
novizio
I'm sorry to ask you stupid, but I think I'm sorry. ! ! !
Until the 2009 version, there was a command that allowed two tubes to be intersected.
now I have to make a pipe graft ad y and I can't find + that command
in the 2010 version can someone help me? ? ?
ps. I do not use the inventor so I am mooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooo
Thank you for your help.
it is called "object copy", but in 2009 it was already so, I would say that it changed from version 11 to 2008 if I don't remember badly, but certainly in 2009 it was already so.
still problems.. .
I'm sorry, but I still can't run this s....zata.
Help me place a seeming exemplary of what I have to do, maybe you let me understand how to work to get the developments of your pipes.
Annex:
double click on short tube
command copy object
select face and touch the outer cylinder of the long tube
select as seperficie output (not composed)
brings this sup over the first extrusion into the working browser
change the extrusion and set "up to" as termination, in the other tab set minimum solution.
That's it!
But if I do, you have a lot of shit in your head! What do you need part 2 in that axieme? do the same sketch in the long tube and get the same result with one part less.
or, and it's the best thing, learn to use the multi-solid available since 2010. You do everything in one part and then you turn it together. simple and fast.
I thank you for the answer to be the result they want even if I did the same procedure.
for your advice I don't know where to start even because I'm applying myself as self-taught without anyone physically to confront me and considering that at work we use for 99% the 2d I have very little time to devote to the inventor.
anyway thanks infinitely
