command reflect line
  • Thread starter Thread starter warcraft
warcraft
Good morning, everyone.
I'm sorry if I'm very reductive, but can someone explain to me what exactly this command is for?
thanks in advance :)
Imagine having to print a shaped tube, to do so you will have to divide it exactly where the surface goes in the subquadra, the command generates a curve on the surface that runs along the points that determine the division between the upper and lower mold
Good evening.
If I may add a clarification in addition to that said by gianni. the command returns one (or more, depending on the shape of the piece ) curves, which correspond to the mold division in the case of 90 degrees and, as direction , the direction of stamping .
However, you can also set different values including the strip required for extraction. So 93 or 87, for example , generates one (or more....) tangent curve to the surface with 3 degrees of sform/spoglia/etc. In this case, from this curve you can then define a surface (swing tangent to the surface or sweep with 3 degrees compared to the molding direction, for example) which allows to make the final piece printable more easily.
This, of course, provided that it is not aesthetic surfaces.
