command txtexp on written curve
Caredan
Good morning.
I am new to the forum so shake me for any errors.
I would have the necessities of having to explode a text that was previously placed on an arc with the command 'arctext'.
the problem arises when I try to type the 'txtexp' command, just to try to explode the text and then extrude it. when I type the blast command, and I go to select the curved text, it does not recognize the written object.
I wonder if there is a way to overcome this problem. Thank you.
txtexp works on texts/mtists, not on objects of type arcalignedtext.
first explore the arcalignedtext object and then use txtexp
but if I do so, the writing changes fonts compared to what I chose in arcalignedtext, could you tell me how I can handle this?
Good morning, Tristan. I apologize if I didn't thank you last time with the reply of December 23, but I didn't notice the notification sent by email. cmq I had solved. Thank you and excuse me again. It is always precious the help you give to all.
