command unknown
  • Thread starter Thread starter strangelittle_girl
strangelittle_girl
when I type some commands I have always typed in autocad 2009 in the command line the message "unknown command".
do you know how to fix this bug?
an example of these commands?
Is it not that you have loaded autocad instead of mechanical?
mainly is an access command to know that from this problem.. on the internet I have seen that others also have this problem with other commands..but the solution is not:(
aaaaargh...
You know... :eek:
Vade retro, satan!!!!
However it may be that the server knows has problems and not connecting the command does not work
