emanuele grasso Guest Aug 8, 2023 #1 hi, I put a step file in solidworks and selecting it does not activate the commando "modification component" as ever? where am I wrong? thanks
Nasicaa Guest Aug 8, 2023 #2 emanuele grasso said: hi, I put a step file in solidworks and selecting it does not activate the commando "modification component" as ever? where am I wrong? thanks Click to expand... What do you mean I put a step file in solidworks? Did you open it? you have to save it and once saved as part you have to break the link with the original file. Then you can intervene on the part. this on v.2023
re_solidworks Guest Aug 11, 2023 #3 emanuele grasso said: hi, I put a step file in solidworks and selecting it does not activate the commando "modification component" as ever? where am I wrong? thanks Click to expand... check if "active 3d interconnect" is activated in system->import options and in case it is switched off.
