comparison of the use of the project in inventor
  • Thread starter Thread starter Antodima77
Antodima77
Good Sunday to all, I wanted a comparison on the inventor project and to understand whether how I am using it is the best way or there are others.
my situation is the following I have several clients suppose 3 each customer uses models, separate tables then loading within the project file specific situations.
2 customers make similar machines among themselves
1 machines always different
the question is this: you for each machine manage a separate project file, regardless of the customer, or create 3 projects where inside there are all the machines of the customer .
p.
subdivision in folders than the 3 customers in turn divided by the type of machine
I hope I've been clear.
I wanted a comparison.
thanks to all
for my small experience in the company where I only use 1 project, but an external designer having different customers uses his project for each customer and therefore his/her tables/free/styles.
hi, I would say you hold a project for each customer, pros are conveniences of division of folders, templates and styles divided by customer, but I can say that even work with a unique project and inside divided by folders, wanting you can have more styles and more templates, choosing it when you start drawing, ie also for material libraries, and for commercials ( screws, dice etc., ) if you don't ask to insert their coding.
