compatibility 2008 2009 2010
  • Thread starter Thread starter smoking
smoking
Hello, everyone.
My problem is easily explained: I use the 2010 version but I need to share files with collaborators who still use 2008. of course they can not open the documents I provide them if not using interchange formats like iges, step and so on. Is there any rescue mode or any particular application that allows you to make files commonly and easily shared?
There's nothing.
non-compatibility is the only real great novelty of each new rel.:biggrin:
Bye.
Wow, it seems to me a sin not indifferent to anyone in the need to share elaborates of different nature. Mah? ! !
Thank you very much for your availability.
but possible that there is no magician of computer science with balls and counterballs that creates an application to overcome the problem?:biggrin:
I mean, what's the difference between an ipt created with 2008 rather than with 2010.
Maybe there'll be some parameters in the file that says with what version it was made, right?
Perhaps it would be enough to vary that data.
Okay, it won't be that simple for all files, but at least those that have no constructive news than the previous version, I think they could be solved.
and I don't think that self-desk or similar might advance who knows what objections!!
However all this for now seems to belong to the kingdom of fairy tales.:frown:
p.s.
I'm sorry about this.
I think it is not a "problem " but a very precise will, a commercial and non-technical choice.
Bye.
can be, you will say that so push more to always have the latest version, although I do not see the commercial advantage of voluntarily creating these problems to customers... And then why don't they do the same with autocad?
It is not that they push but they force! !
autocad is entry level acquire customers who then sodomizzano with convenient over the years! !
I don't want commercials and retailers.. It's not their fault.
They did it with autocad.
I do not remember in which version there was no longer the possibility to save to rel. 2000 or 2004.
there was the revolt of the users and, magically, such possibility is reappeared.
It can also be thanks to the competition (solidworks), which has, with a brilliant hand shot, made available the " dwggateway ".
Bye.
