gerod
I leave you some useful links on complex machines.http://www.machinebuilding.net/n/n2630.htmhttp://www.hse.gov.uk/work-equipment-machinery/manufacturer-in-situ.htm?ebul=hsegen&cr=14/6-may-12
It's hard to read. . .the machinery directive 2006/42/ec applies to assemblies of machines as well as to individual complete machines where they are:
- assembled together to carry out a common function,
- the constituent parts are functionally linked in such a way that each unit affects the operation of other units so that a risk assessment of the whole assembly is necessary, and
- the constituent units have a common control system.
If you do risk analysis and do not add risks then you do not have to mark there the plant.the definition of machine sets indicates that sets are arranged and commanded in order to have a solid functioning, to achieve the same result. To ensure that a group of machines or machines is considered as a set of machines must be satisfied, all the following criteria:
− the constitutive units are mounted together in order to perform a common function, such as the production of a given product;
− the constitutive units are functionally linked so that the operation of each unit directly affects the functioning of other units or the whole of the unit, and therefore a risk assessment is necessary for the whole;
− the constitutive units of the whole have a common command system – see §184: comments on point 1.2.1, and §203: comments on point 1.2.4.4 of Annex i.
a group of machines connected to each other, but in which each machine works independently from the others is not considered a set of machines in the sense indicated.
Let's talk about it.after the installation of the robot, should the plant be certified?
