complexv composed of several axiemi (exploses "singolarly")
disperso
Good evening to all, I had already introduced myself but it's been several years... I am a Tuscan designer who mainly deals with lighting and furniture... design objects with a total of 100 details.
I looked in the forum, but I didn't find answers... You don't want me if I wasn't able to do the right search.
said this, I use version st6, my problem is rather "simple": I have different models of lamps, which being part of a unique series, have axiemi in common (already exploded for the tables in detail). When I go to insert these modules into other models I find myself faced with the need to explode all the lamp and at this point, since the inserted module already has its own explosion, I would like to be able to use it and after explode the rest of the frame.
How do I reuse the explosion of a set contained in another set?
thank you in advance and excuse the repetitions, but I couldn't find synonymous.
when you were in the environment, select the axieme on which the explosive to be recalled is present, then see if in the list of explosions you have the possibility to use the stored configurations.
in the environment together this works, in the environment it was never tried.
I don't see an option regarding the "Led Parable", I attach an image.
