component/model in reference with a given color
  • Thread starter Thread starter DoctorBomber90
DoctorBomber90
Good morning, everyone.
I'm just using inventor 2023.
I have a question to ask you, as to put an element in "reference".
if they select the component that, initially, is in "default" and decide to put it in "reference", inventor does not change the surface(or skin) with a different color. i.e. if the model is totally gray (and is by default) and I put it in reference, he always shows gray.
I wondered, if possible, give him a particular color (blue or blue type) to the model when I put it in reference.
I tried on the forum if it had already been treated as a subject of some discussion but it was never treated.
Thank you very much in advance.
does not happen automatically, but when selected a component you can set the look you prefer. the reference status affects the component lists and the graphic representation at the table (if I do not forget anything)
Thank you very much. So there's no automatic way to make him change the color when you refer to it.
