component sub-assistance.
  • Thread starter Thread starter xxfast
xxfast
I would need to replace components in the subaxieme pippo from the axieme 1. I can't get rid of a few pips parts to replace them, working from the aid 1.
Moreover I would need to replace the components in question only in the context of the aid 1.
How can I do that? :eek:
Perhaps you should duplicate the pippo axieme pippo1 go to make the changes of the case and then in the axieme1 replace the sub together pippo with pippo1.. .
I thought it was possible to replace a component in a subaxieme, without changing the subaxieme in question in the other files where it is used.
I mean, without changing the subaxis.
I think you already understand.
replacing a component in the subaxieme together_1 you have to do it directly by opening the file together_1, you can't do it as a modification of the subaxieme together_1 .
said this, if in a subaxieme together_1 gates leave and replace it with childbirth, it is clear that together_1, wherever it is used, will no longer have to leave.
if you want to have both options you have to add also partb and create in the assembly together_1 two configurations that alternate the suspension of the parts a and b.
Well, I had half intuition.
the fact is I don't use the configurations yet.
If you kindly put me on the good road, maybe I start using them.
How do you create a configuration?
In the meantime, I see about the help.
