Davimont
Every now and then I have to do suction pipes with a dorsal and drops that maybe end with arms or simple mouths.
not being heavy aspiration jobs, we have always foreseen a diameter of conduct from the beginning to the end of the same diameter but we know that the more you get away from the fan and the more the conduct should go to tighten of diameter.
are you aware of some calculation sheet having to be able to put the basic data as a fan's reach, number of drops and perhaps the speed required within the pipelines? I don't want to draw anything, it would be enough for me to have basic data to make the system more correct and order the pipes of proper diameter.
if then there is an open source software that integrates other calculations, well come.
who does these works habitually, how do these calculations?
