gfrank
a new command is conditional formatting usable in revit abachi
It's a very comfortable function that almost completely follows excel's.
In plain words, conditions can be defined and the appearance of this condition changes the graphic aspect of certain cells of the computation.
to activate the conditional formatting management window you have to press the alt-n key combination when you are inside the abhoc property window formatting page
a screen will appear where you can choose which field to check, the operator to use and the value to use as a control.
