condivisione file
  • Thread starter Thread starter albertos
albertos
hello to all, I wanted to ask for information,
I have a set made solid works 2010 on PC notebook s.o view 32 bits, I can not view it on one of the pcs of the office when the exchange is apparently always optimal.
I explain the workstation with a view 64 opens the axieme without problems, while in the workstation with xp 64 remains in the opening phase and never loads while the individual parts I manage to drive them perfectly!
software apart from updates is the same sw 2010, what can be the problem?
I use xp-xp64-win7x64 and I have never had probelmes of this type. Are you sure it's swx and not the car with a view?
we found a problem on the pc, changing workstations, what pc do you recommend to me to get? work with big assemblies and the configuration recommended by the sw is the right compromise, or need something more?
Thank you!
Hello everyone
I think the problem is 64 bit. I have a 32 bit and turns perfect, with 64 bit I had a lot of problems. . .
never had problems with 64 bit. I used both xp and seven and always with excellent results. I've only got a 32-bit PC and all the problems that happen to me on the 64s are also on the 32.
64-bit solidworks is certified as the 32 for microsoft operating sisyemi and has the same compatibility. if particular problems have arisen for some users, at least in recent versions, it means that the 64-bit machine has not been configured and/or installed correctly.
Hello to all boys
I have to draw an elliptical form "full" with axes data and bases... I don't remember how to do it with sworks... Does anyone have any suggestions? ? ? ?
other question-->I can't see the bending lines when amounting a flat repetition in the drawing sheet.... why??? ? Thank you.
Hello to all boys
wouldn't it be the case that you opened a new discussion (in 2 in this case)? What does this have to do with the subject of the original post?
then you are prayed not to write in capital print, in the online "language" is equivalent to screaming.
Mar
Sorry I'm new and I don't know.
1.I don't know how to open a new discussion, do you explain??? ? Thank you!
2.This maius screamed I never heard of her, but I treasure.. .
1) on the first page (the index) of each forum by topic (solidworks in this case) there is a nice pulsizer new thread, both at the top left and at the bottom left.
2) the "netiquette" is as old as the internet itself (try to googlare).
Marco:smile:
