cone octagonal sheet
  • Thread starter Thread starter themole
themole
Good morning, I should create a sheet cone sp=4mm on 2 octagonal flanges a large and a small one.
cone length about 800mm.
Is someone so kind to tell me how to proceed?? (loft etc.etc.)
Thank you in advance.
if by flange you mean lower base and upper base, it is not a cone but a cone trunk. as the figure is straight, it is necessary to calculate the height of this cone, whose summit is located at the meeting point of the 8 folds that compose it.
Being a polygon with 8 angles, each of 45°, you can consider the neutral fiber at the center of the thickness ( factor k = 0,5 ), for the calculation of developments.
