configuration graphic tablet
  • Thread starter Thread starter Mauromz
Mauromz
Good morning, everyone.
I own a graphic tablet trust wide screen design tablet.
the problem I have and I have placed is to try to configure the tablet based on the 2010 autocad screen without the runner running holes from the edges.
I tried to use the board command of autocad 2010 with its various options, but nothing changes. Does anyone know anything about it? Thank you.
in my modest opinion using a graphic tablet on autocad is a stupidity...not in the sense that it is simple but rather useless and does not increase your productivity
Thank you, I thought I'd be stunned I couldn't calibrate her.
the fact is that he sometimes happens drawings on paper epnsavo to use the tablet to repass it. But I always have the difficulty that the cursor comes out. So I thought there was a way to calibrate it/configure it through the boarding command that honestly at this point I don't know what it is for
... without the runner running holes from the edges.
when you do the calibration with the tab/calibration command you are sure that the coordinates you entered to specify the second point then actually fall into the current screen?
Maybe it would take a zoom.
Imagine having to digitize an a4, enter as coordinates for the first point 0.0 and 210,297.
in the drawing draw a rectangle with those same values and zoom and see it in full.
the cursor should move inside the rectangle.
